Capacitor's for 63 on cluster - NCRS Discussion Boards
  • Greg W.
    • August 31, 2005
    • 117
    The black wire came out of one of the capacitors.
    Fixable? Replaceable? Needed?
    Thanks for any help on this.
    Greg
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: Capacitor's for 63 on cluster
    The capacitor was there to minimize electrical "noise" in the radio. If your radio performs adequately in its present state, then the capacitor becomes a "correctness" issue.
    Repairable? No. However there was an article in a past RESTORER where someone was able to reuse the capacitor can and install a new capacitor inside, retaining the external appearance, wire, etc.
    You could also attempt to carefully drill a hole into the existing capacitor and glue the wire into the hole. obviously the capacitor will not function electrically.
    You can replace with a new capacitor but "originality" suffers. You also might luck out and find a used one $$$$.
