I should know this answer from all the help I've received here on my stiff clutch issues in my 60 but before I commit myself I need to know for sure...
Will the bellhousing, flywheel, starter etc from a 71 GMC or Chev 1/2 ton 6 cyl fit and function properly in my 60 Corvette?
If I understand what other have said correctly I think it will but I'd like some confirmation on that before I go to all the trouble of removing the truck parts. I know the bellhousing won't look 100% correct with the mounts pads but if that is the only issue then I'll run back to the wrecker and grab these parts while I can. This way I can get it working properly and worry about getting the proper 60 only aluminum bellhousing later.
) but I what I really would like to know is if I can grab a bell housing, flywheel, starter, etc out of a late 60s-early 70 Chev truck.
