My 66 327 350hp Holly carb. is stamped , top 3884505-DA, MIDDLE 3367, BOTTOM 3528. I believe the top and middle numbers are correct but I can't make out the bottom ( date ) numbers. when was this carb manufactured ? Thanks. will I lose pts. if judged. The car was made in Nov. 65
66 holly carb. date on manufacture
Re: 66 holly carb. date on manufacture
Shelby,
If the bottom number is 4 digits, your 3367 carb is a replacement carb acquired after, I think, 1972. That is when I think they changed from the 3 digit to 4 digit julian dating, day of the year and last digit year.
From the number you posted, the carb was manufacter in December, 1978, or 1988. Maybe 1998, if they were still doing replacements.
The way they dated these replacements, I guess they didn't expect the carbs to last 10 years
Not sure of the deduct but I think it is minor.Jerry Fuccillo
1967 327/300 Convertible since 1968- Top
i believe the 4 digit bottom # means it is a over the counter replacementMy 66 327 350hp Holly carb. is stamped , top 3884505-DA, MIDDLE 3367, BOTTOM 3528. I believe the top and middle numbers are correct but I can't make out the bottom ( date ) numbers. when was this carb manufactured ? Thanks. will I lose pts. if judged. The car was made in Nov. 65- Top
