A/C Scraeder Valve Caps - NCRS Discussion Boards
  • Clark K.
    • January 12, 2009
    • 536
    Can anyone tell me if the cap shown in the attached photo is correct for a 1965 C-60 system? I have been told these are correct but would like some second opinions from you guys. -Clark
  • Ken A.
    • July 31, 1986
    • 929
    Re: A/C Scraeder Valve Caps
    No, it should be flat on top and round on sides with a knurled machine finish for gripping.
    • Gary N.
      • August 31, 1986
      • 118
      Those are the ones that are on my 66' also.
      Gary Nyland
      1966 Black Corvette Air Coupe
      2014 Black Z-51, 3LT Coupe
      1955 Black Chevy Belair Gasser
      1955 Nomad
      • Dick W.
        • 10483
        I know the ones in the photo are correct for '68-'72, but not sure about your '65
        Dick Whittington
        • William C.
          • May 31, 1975
          • 6037
          Those are indeed correct for the '65 units, the knurled flat-top items were later. There should be two of the on the manifold that mounts at the rear of the compressor, one pointing outboard to the pass side and the other pointing outboard to the drivers side.
          Bill Clupper #618
          • Mike G.
            • January 1, 1991
            • 418
            Those match Dobbins and Adams photos
            They also display the same logo as my original late 64 compressor muffler as well as the vacuum switch for the water flow valve.
            • William C.
              • May 31, 1975
              • 6037
              Picture attached of original unrestored '65 car with original air fittings. Email me if you want a larger version as the one I have will have to be resized to fit his forum.
              Bill Clupper #618
              • Gary N.
                • August 31, 1986
                • 118
                The acorn caps on my 66' are on the scraeder valves (2) on the back of the compressor. Mine has the round one with the flat top and ridges on the STV valve, like the one shown in the picture above. All are brass.
                Gary Nyland
                1955 Nomad
                • William C.
                  • May 31, 1975
                  • 6037
                  I believe that would be correct for the STV to have the knurled cap. Also note the configuration of the block on the back of the compressor, round at the outboards with a horizontal dip in the center.
                  Bill Clupper #618
