67 BB automatic clunk - NCRS Discussion Boards
  • Larry S.
    • March 11, 2007
    • 457
    I have a SB 67 with automatic and a 67 BB (400HP) with automatic. The SB goes into reverse and drive fairly smoothly, but the BB makes a rather loud clunk, particularly going into reverse. Is that just because of the heavy-duty transmission used on BB's? Otherwise, the tranny shifts fine.
  • Scott S.
    • March 1, 1979
    • 747
    Re: 67 BB automatic clunk
    Check all your driveline components for tightness. Also the Pinion snubber bushing.
    Scott
    • Larry S.
      • March 11, 2007
      • 457
      Thank you!
      • Tom L.
        • October 17, 2006
        • 1439
        Definately check the snubber bushing. Mine was toast, replaced it and the reverse "clunk" long gone. Have fun!!
        • Larry S.
          • March 11, 2007
          • 457
          I've checked the Corvette Central and Long Island Corvette websites, and I find no pinion snubbing bushing. Would someone give me a lead?
          • Tom L.
            • October 17, 2006
            • 1439
            Here's a link to the correct rubber parts. you need the upper and lower bushing. Some don't like the the poly replacement but I found out after I installed mine. I've had no problems. Good Luck!!!
              Larry -
              Paragon #6527K has the complete kit - upper and lower bushings, bolt, nut, washers, etc. - that's the OEM rubber cushions with a bonded washer and molded-in steel tube sleeve that keeps the diff bracket isolated from the frame bracket. The poly bushings have none of those features, and are too thin, resulting in very little clearance from the U-joint to the tunnel surface.
