what paint for 68 PS pump? is kryon semi-flat a good choice? - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    Manual says semi-gloss but I have some kryon semi-flat I think 1613 is the number of it.
    is this close enough or will it lack in shine from what it was originally? wonder if I should prime it? Right now it's bead blasted.
  • Martin N.
    • July 30, 2007
    • 594
    Re: what paint for 68 PS pump? is kryon semi-flat a good choice?
    BRANDON-
    Hit with a light coat of Krylon primer and use a Fine grit Scotch Brite pad on it, then a couple coats of the #1613 and it'll look great. Been there, done that.
    Marty
