I then looked back at an older 2004 post of yours where you say the 3940991 was the correct belt from production and the 3871257 was a non-correct service replacement.
For my application the dimensions of the 3940991 would seem to be perfect as it is wider and shorter.
What the definitive answer Joe?
Thanks!
[FONT='Tahoma','sans-serif']February 24th, 2009, 05:03 PM [/FONT]
[FONT='Verdana','sans-serif']Joe Lucia (12484) [/FONT]
[FONT='Verdana','sans-serif']Beyond Control Poster[/FONT]
[FONT='Verdana','sans-serif']Join Date: January 31st, 1988[/FONT]
[FONT='Verdana','sans-serif']Posts: 21,473 [/FONT]
[FONT='Verdana','sans-serif']Re: What's wrong with this pix....69 alt belt problem.[/FONT]
[FONT='Verdana','sans-serif']Quote:[/FONT]
[FONT='Verdana','sans-serif']Originally Posted by [/FONT][FONT='Verdana','sans-serif']Lynn Schwebach (42902)[/FONT]
[FONT='Verdana','sans-serif']Thanks, would greatly appreciate the help as Quanta did not seem to know of a problem. I purchased one of the alt belts from Paragon, but that shoudn't make a difference?? Lynn Schwebach[/FONT]
[FONT='Verdana','sans-serif']Lynn----
The alternator belt for your application should be GM #3871257 and be 3/8" X 54-3/4". Is that the part number on and dimension of the reproduction belt?[/FONT]
[FONT='Tahoma','sans-serif']September 28th, 2004, 08:21 PM [/FONT]
[FONT='Verdana','sans-serif']Re: L-71 Alternator Belt[/FONT]
[FONT='Verdana','sans-serif']Rich-----
Yes, GM #3940991 was the PRODUCTION alternator belt. This belt was a 15/32" X 53-1/2" belt. This is a real "oddball" size that you'll only obtain these days in a reproduction belt. For quite a few years, the belt that GM sold in SERVICE for this application was the GM #3871257. That belt was 3/8" X 54-3/4". It's not inconceivable that some of these MAY have found their way into PRODUCTION, too.[/FONT]
