Putting in the radio, what is the procedure as far as what pieces come off the radio before it goes in the hole, radio has the entire face on it, buttons, scan bar with the two nuts holding the plate on, do those nuts come off as well as the chrome piece then insert then put the chrome back on then the nuts, or does it go in the hole as is then
the repro kit go on over that, what order then, nut which holds the radio to dash against other nut then selector piece, spacer, felt washer then knob, is their their a spacer on the right side as well with 2 ears like the left side or what? thanks Brad. Also the speaker wires to radio green to green then power to other little green wire must plug into transformer? Again thank you Brad.
