Technical drawing of Midyear Convertible Top Frame - NCRS Discussion Boards
  • Bill T.
    • March 1, 1999
    • 55
    Anyone have a detailed or engineered drawing of the Midyear top frame?
    I am still fighting with the top bows and having limited success lining them up to the windows properly. The two pieces of weatherstrip directly above the drivers window form a "V" instead of a straight line "__" and I have not been able to cure this. Somehow, there has to be a way to bend, twist, shorten something to correct this problem.
    Suggestions? Directions? Contacts?
    All input appreciated...
  • Bill T.
    • March 1, 1999
    • 55
    Re: Technical drawing of Midyear Convertible Top Frame
    I've got to run this through again.
    I've looked at dozens of cars and a good fitting top that matches the weatherstrip is a rarity. I can't believe that there isn't someone who understands the geometry of the folding top and can make it fit properly. I don't want to join the ranks of those that say " It's gonna leak..."
