Mysterious engine shut down. - NCRS Discussion Boards
  • David N.
    • June 30, 1991
    • 142
    After rebuilding and reinstalling my 427 in our '69 I have encountered an unusual to me problem. The engine starts up just fine. After running for 10 to 15 seconds it just shuts down. Any thoughts on a cause? It can be restarted too.
    David #19639
    • 6940
    Re: Mysterious engine shut down.
    Dave, are you starting up a cold engine when stalling out? does it re-start right away?has the engine spec.s been set (timing, dwell, idle mixture, idle speeds for cold start and warm engine).
    • Timothy B.
      • April 30, 1983
      • 5177
      David, After the car shuts off don't touch anything and get a test light to see if there is current at the + terminal of the coil. This will eliminate the ignition switch and wiring up to the coil.
      Process of elimination to see if it's electrical or fuel.
      • David N.
        • June 30, 1991
        • 142
        Ed & Tim, Thanks for your posts. The timing, points & etc are OK. I started it up and when it died I checked the voltage at the coil terminals, 0 volts. Looks like I will be doing some electrical checks tomorrow. Thanks again.
        David
        • Stuart F.
          • August 31, 1996
          • 4676
          With a straight forward points ignition system, the usual thing to look at for a start/stall condition is the ballast resistor. However, since it sounds like you just put everything back together, you must recheck all connections that you made in the process.
          Stu Fox
