Re: BB hypereutectic piston source
Michael-----
Keep this in mind: if you build an engine with a compression ratio that results in unacceptable pre-ignition/detonation that cannot be resolved through "tuning" (and, in many cases, you won't be able to resolve such a problem through "tuning"), your options will be limited to the following:
1) use expensive and inconvenient racing fuel:
2) use expensive, inconvenient, (and illegal) aviation fuel;
3) use expensive and inconvenient octane boosters in every tank of fuel;
4) tear the engine back down and replace the pistons.
The above is why engine builders who build STREET engines are very conservative with compression ratios and I strongly suspect why GM uses a compression ratio of 8.75:1 in all cast iron head big block engines.
Michael-----
)...did not detonate. Have purchased O/E style blue print cam shaft for use at rebuild.
? Thanks.
