i see 2 ways to mount the shifter on my 66 a trans mount and a frame mount. what dictates the mounting method? the shifter or trans or niether? i have a nov 22nd build. it currently has a fact looking hurst.
muncie shifter mount on a 66
Re: muncie shifter mount on a 66
Bill --- It was a running change at the St.Louis assembly plant. If no one comes up with the date or VIN, I can dig into my Tech Service Bulletins tomorrow. I believe a definite VIN # is quoted for the mounting method change.- Top
Bill, as wayne mentioned, there was a TSB that showed the date the change from transmission mounted to frame mounted shifter occured. That date is 21 March 66.- Top
Tradeoff was more precise shifting with the trans mounted unit, less vibration with the crossmember mounted unit. The crossmemer in the frame will not have the holes added for the mount if the car was equipped with the trans mounted shifter, at least until very close to the changeover.Bill Clupper #618- Top
