Re: Is this the 359942 pan?
Steve-----
No external baffle was used for 1969 L-46. So, you don't need a baffle or the special main bearing cap studs.
The 1969 L-46 is generally described as "high performance" (HP) and not "special high performance" (SHP). The 1983 P&A catalog excerpt you posted has multiple application errors on the line you hi-lited. First of all, there was no "SHP" for the 1969 model year. There was supposed to be as the LT-1 was scheduled for 1969 model year introduction, but never released for that model year. Nevertheless, some references to 1969 SHP (i.e. LT-1) have "crept" into the P&A Catalogs.
Second, the 3820001 (or, 1976 era replacement GM #359942) was not used for all 1970-71 LT-1's. It was used only for early 1970 LT-1 without N-40 and all ZR-1 (described in the P&A Catalogs as "SHP with HD 4 speed"). It was not used for any 1971 LT-1 except ZR-1. The same held true for 1972.
Steve-----
