I recently purchased a new set of 66 BB reproduction shielded spark plug wires from Lectric Limited. The set comes with installation instructions which give exact lengths for each wire in the set of 8. These plug wires are designed to fit exactly as from the factory. The instructions say to be sure to connect the correct length wire to the correct cylinder using the correct ignition shield brackets and the correct holes in the rubber wire guides.
They include a chart which uses the words: "Wire NO: 1, 34 inches", wire NO: 2, 31 inches, Wire NO: 3, 31 inches, Wire NO:4, 27 inches, Wire NO: 5, 22 inches, Wire NO: 6, 25 inches, Wire NO: 7, 22 inches, Wire NO: 8, 21 inches."
I know some of you have done this before, so before I guess and make a mistake , could someone please confirm that the words "WIRE NO" actually mean "CYLINDER NO" ....and that the 34 inch plug wire actually goes to CYLINDER NO: 1 and so on....
Thanks for saving me having to do this by trial and error.
Now I just have to hope my Distributor is installed/positioned correctly in the block.
