After finally removing the evaporator core box to get to the A/C compressor hose assembly, I did manage to separate the POA from the evaporator core, but am still unable to separate the hose from the POA valve.
I've tried Freeze Off spray, PB spray, ammonia (to break down aluminum oxide), and even took it to a local shop to see if they could get the nut loose - all with no result. Their next suggestion was to split the nut to save the POA valve, as they were concerned that they'd twist off the POA threads.
Any other suggestions? I'm assuming that it would be easier to find another hose end than it would be to find a correct date-stamped POA.
Thanks in advance.
Randy
Thanks in advance.
Randy
