Brass screen - NCRS Discussion Boards
Brass screen
  • Steve B.
    • March 1, 2002
    • 1190
    Brass screen
    I just had my 67 judged at Bloomington and received a deduct because the screen for the windshield washer bottle was not brass. I seem to remember someone on the driveline advertizing these but cannot find it now. Does anyone know who sells these? Thanks in advance.
  • Jim T.
    • March 1, 1993
    • 5351
    Re: Brass screen
    How much was the deduction?
    • Mike M.
      • May 31, 1974
      • 8365
      Re: Brass screen
      hit your local junkyards as the brasss filters were used in other GM makes of the '60s.mike
      • Dan H.
        • July 31, 1977
        • 1365
        Re: Brass screen
        Richard Fortier sells them in Driveline. Give him a call.
        Dan
        1964 Red FI Coupe, DUNTOV '09
        • Steve B.
          • March 1, 2002
          • 1190
          Re: Brass screen
          Jim, the deduct was 5 points out of approx. 9000 points available.
          • Mike G.
            • January 1, 1991
            • 418
            Re: Brass screen
            Model shops should have this material. I've seen it used to make domed filter screens on velocity stacks for F1 car models.
            • Chris E.
              • November 3, 2006
              • 1322
              Re: Brass screen
              Ok, so where is that brass screen installed? Do you have an A/C car and we're talking about the BAG style of washer reservoir?
              When I took my car apart, I don't remember seeing any screen installed inside the washer reservoir.
              Chris Enstrom
              2011 Z06, red/red
                Re: Brass screen
                The screen is on the black plastic nipple on the hose that's submerged in the washer fluid; the original nipples had a brass screen, and the reproductions and service replacements have a stainless screen.
                • Rick A.
                  • July 31, 2002
                  • 2147
                  Re: Brass screen
                  Steve,
                  can't believe you had a FIVE point deduction just for the screen!
                  Rick Aleshire
                  2016 Ebony C7R Z06 "ROSA"
                  • Chris E.
                    • November 3, 2006
                    • 1322
                    Re: Brass screen
                    John, thanks for the clarification. Does this fall under the guidelines of what judges are SUPPOSED to remove to judge a car? (like air cleaner, and ignition wiring cover)
                    Chris Enstrom
                    2011 Z06, red/red
                    • Steve B.
                      • March 1, 2002
                      • 1190
                      Re: Brass screen
                      Originally posted by Rick Aleshire (38392)
                      Steve,
                      Rick, 5 points does seem like a lot but that is out of about 9000 points available so its not as bad as it sounds. I was very happy with the judges, which were tough but fair, and how the car did.
                      • Dick W.
                        • 10483
                        Re: Brass screen
                        5 points is the minimum deduction on an item at BG. Takes the variables out of scoring. ?
                        Dick Whittington
                          • 11608
                          Re: Brass screen
                          Steve,
                          Rick,
                          If you recall, ALL of the deductions at Bloomington are 5 point increments. There are no 1/2/3/4 etc levels of deduction. Only 5/10/15, etc. So, the "smallest" deduction is 5 points.
                          Patrick
                          • Pat M.
                            • April 1, 2006
                            • 1575
                            Re: Brass screen
                            What year Vette(s) used the brass screen as OEM?
                            • Rick A.
                              • July 31, 2002
                              • 2147
                              Re: Brass screen
                              Patrick / Fat Little Buddy,
                              massive brain fart on my part - blew right over the fact that is was Bloomie!
                              Rick Aleshire
