'61 Interior Paint color - NCRS Discussion Boards
  • Richard P.
    • July 31, 2001
    • 173
    What is the best paint to use on 1961 interior components (dash cluster kick panels, etc) to achieve the correct sheen and pass judging?
  • Glenn D.
    • May 31, 2002
    • 137
    Re: '61 Interior Paint color
    I used SEM products when I restored the interior of my 74'. The attached article my be of interest. You can purhase SEM from a local interior shop or Eastwood. http://www.corvettefaq.com/c3/VinylDying.htm
    Prep is to key to a good result.
    • Ray C.
      • June 30, 2001
      • 1132
      PPG Duracryl Lacquer
      Ray Carney
      1961 Sateen Silver 270-HP
      1961 Fawn Beige 315-HP
      • Glenn D.
        • May 31, 2002
        • 137
        If you have any plastic pieces that need repair this works very well. Once you get the technique down , the result is very good. I repaired a rear dogleg that was broken in half. After dyeing the part it was very hard to see where the repair had been done.
        • Richard P.
          • July 31, 2001
          • 173
          Will "single stage" paint work?
          • Gene M.
            • April 1, 1985
            • 4232
            If you want it to look correct without the "thick" look then Ray Carney is correct lacquer is the only choice.
            • Dennis A.
              • April 30, 1999
              • 1010
              Richard...
              Lacquer... Steering cover, Hub, and turn signal housing and the steering column down several inches below the turn signal housing are "unbuffed". A semi-gloss for these areas works well.
              • Richard P.
                • July 31, 2001
                • 173
                Are the side kick panels Buffed to a gloss?
                • Richard P.
                  • July 31, 2001
                  • 173
                  I found a site for two types of lacquer. One is Restoration Shop Acrylic Lacquer, the other is PPG Duracryl DDL acrylic lacquer. The PPG is more than double the price. Any experience with these?
                  • Dennis C.
                    NCRS Past Judging Chairman
                    • January 1, 1984
                    • 2409
                    If you want to duplicate OEM appearance, nothing is done to the interior paint, no sand, no buff, no nuthin...
                    • Dennis A.
                      • April 30, 1999
                      • 1010
                      RICHARD...
                      Most all lacquers in the rattle-can are good, I look for color match and a bottle of touch-up to match. Paintscratch is one source and will customer mix if required.
                      The Side-Kick panels should match the heater cover, package tray, end-caps, center console,etc.
