66 trailing arm brake line - NCRS Discussion Boards
  • Brian K.
    • May 31, 2004
    • 358
    I got a March built 66 roadster, I was wondering if the steel brake lines on trailing arms should have coiled armour or not? I checked the judging guide and could not find any reference. Thanks in advance Brian
  • Brian K.
    • May 31, 2004
    • 358
    Re: 66 trailing arm brake line
    I thought I would give this a bump.
    • Gene M.
      • April 1, 1985
      • 4232
      Brian,
      Armor on the two short rear caliper lines in 65 and 66.
      • Brian K.
        • May 31, 2004
        • 358
        Thanks Gene, sincerely Brian
        • Francis F.
          • April 1, 1978
          • 420
          our June "66"coupe had just the plain non/coil type orig
          steel lines,just an observation(.02 $)
          francis
          • Wayne M.
            • March 1, 1980
            • 6414
            Originally posted by Gene Manno (8571)
            Brian,
            FWIW, a GM prototype 1965 pic on page 261 of Noland's Vol 2 shows no armor on a caliper brake line that seems to be on a big block car (ie. linkage and rear sway bar show clearly).
            Any of you guys ever seen the early design pad retaining pins held in the caliper with TWO hairpin clips (ie. not the single clip on one end and a nail head on the other end of the pin).
