63 Electrical Wires - NCRS Discussion Boards
63 Electrical Wires
  • Greg W.
    • August 31, 2005
    • 117
    63 Electrical Wires
    After installing my cluster, steering column, radio and clock, I guess thats all the electronics on a 63; I still have two wires left over. I need help.
    I have a green wire the has 12V and a black with 0V, where could they go.
    My parking brake light does not work but thats because I just found out there is no wire going to the back of the switch. Where does it start and stop?
    Wiper motor worked the first time I turned on the battery and went to high and then tried to turn off and nothing. Then on its own good time it turned off and went to the park position. The motor was sent off and rebuilt, so I assume I have a grounding issue or a bad switch?
    Left turn signal does not work, was having an issue with it prior to dash, I think it has something loose at the bulb.
    Any help?
