I just cut out the openings in the dash pad for the defroster ducts and now I'm wondering what the finished opening should look like as seen with the defroster moldings in place? As it is now, you can see the yellow foam from the dash so I'm currious to know if this is correct or if this "cut edge" should be the same color as the dash or black or.....
Also where could I find a used set of defroster ducts(under the dash)? Mine were never reinstalled after the dash was replaced and they didn't come with the car either so I'll need a set. If someone could point me in the right direction I'd appreciate it.
