I have lost some alignment shims ( '64 roadster) on the trailing arms so Ive got to have a realignment done. If after alignment (using the slotted shims) I drill and pin with the cotter keys supplied with the shim kit, will this cost me points in judging? If so, then is there another solution to stop these shims from falling out, assuming I use slotted shims?
Also,I checked my '66 coupe and they are working out too!
