Re: Erratic amp gauge reading
When the gauge was "bouncing around" was it favoring the plus side? Mine was. I had this happen almost two years ago and problem was a cell in battery gone bad. It still had enough power left to start the car. But shortly there after it started to fail even after having put on a charger to attempt to keep it up.
Replaced battery and regulator and the problem was gone. Charge is normal and battery is strong.
Make sure the regulator is set up correctly and grounds clean and tight. The battery can be damaged as well as alternator if not.
