67 Big Block Accelerator Ground Strap - NCRS Discussion Boards
  • Douglas L.
    • August 31, 2003
    • 299
    If anyone has a picture of the original orientation of the accelerator ground strap for a 67 big block, could you post one? Thanks in advance.
    Doug Lee
  • William L.
    • December 1, 1988
    • 944
    Re: 67 Big Block Accelerator Ground Strap
    Doug hope this is what you are looking for and yes the strap goes under the Ing. shield bracket.Bolt for the ground to lever is a star washer.
    Bill
    Bill Lacy
    1998 Indy Pacecar
    • Michael H.
      • January 29, 2008
      • 7477
      Bill
      Are you sure about the star washer? I don't remember one there on the big blocks I've owned. Could be right though.
      • William L.
        • December 1, 1988
        • 944
        Micheal; The A/M calls for a "lock washer" I was told that it was a star washer but I am not sure. I have never been called on it.
        Bill
        Bill Lacy
        1998 Indy Pacecar
        • Michael H.
          • January 29, 2008
          • 7477
          Bill
          Yup, it even looks like an external tooth lock washer in the drawing. I wonder what type washer is shown in the standard parts book under that part number.
          That washer must have been added for 67 because there was no washer of any kind called for in the 66 AIM for the throttle lever.
          • Douglas L.
            • August 31, 2003
            • 299
            Bill,
            Good pic. When you go full throttle, does the ground strap hit the firewall?
            The strap on my car is broken at the point where it grounds to the motor. It was installed exactly like yours(but no star washer). I am replacing the original strap with a repro. When I move the accelerator linkage to full throttle, the new strap hits the firewall. But, there is no mark on the firewall where the old strap might have hit.
            I have seen at least one car where the strap was mounted going forward on the accelerator bracket and "s" ing around the front of the accelerator bracket and "s" ing back to the motor. But the way your strap is oriented is the way my old strap was oriented.
            The assembly guide seems to be more representative of the small block strap. Maybe somebody else with an original BB strap setup will chime in on this one.
            • William L.
              • December 1, 1988
              • 944
              Originally posted by Douglas Lee (40617)
              Bill,
              Doug; Yes does hit the firewall. See first picture. I did not know it. So I moved it to the position that is shown in the A/M and it no longer hits the firewall. See second picture. Thanks I never knew it hit. By the way the lever is the same for big and small block that's why it shows just one picture in the A/M.
              Bill
              Bill Lacy
              1998 Indy Pacecar
              • William L.
                • December 1, 1988
                • 944
                Micheal; I have a 1973 Corvette Parts Book and I could not find that part # for that star washer but I did come across something interesting. It shows the proper way stat washer should be used on ground straps.
                Bill
                Bill Lacy
                1998 Indy Pacecar
                • Dale S.
                  • November 12, 2007
                  • 1224
                  Finally got the grease off my ground strap where I could see the thing. It does have a star washer between the lever and the ground strap. (SB). Amazing what you can find when you know what to look for. Thank you. Dale
                  • Douglas L.
                    • August 31, 2003
                    • 299
                    Dale,
                    Thanks for the update and checking on the ground strap.
                    Doug Lee
                    • Timothy B.
                      • April 30, 1983
                      • 5177
                      I don't think the part #'s for the strap are any different from small to big block. When I installed mine it's pointed forward and down and forms a S to attach to the intake bolt under the wire bracket. When I removed the old spade from the lever it was oriented that way so it seemed logical for the S routing..
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        Bill
                        Looks like the washer was added for the 67. This is the AIM sheet for 66 and no washer is shown in the drawing or parts list for the throttle lever ground strap.
