Horn Relay - NCRS Discussion Boards
Horn Relay
  • Les G.
    • December 5, 2008
    • 158
    Horn Relay
    NEED ADVISE, 1970 THERE IS A BLACK WIRE ON THE HORN RELAY EVERY TIME I HOOK IT UP THE BUZZER GOES OFF. REPLACED THE RELAY TODAY SAME THING HAPPENS AC DELCO RELAY. THIS IS WITH THE KEY IN OR OUT OF THE IGNITION. TRIED PLAYING WITH THE KEY A LITTLE BIT AND THE BUZZER STOPPED FOR A SECOND. IS THERE A SWITCH IN THE STEERING COLUMN? WOULD SOME WD-40 FIX THIS? ANY RECOMMENDATIONS.
    Re: Horn Relay
    Les -
    Yes, there's a tiny key buzzer switch inside the steering column; the steering wheel has to come off and the turn signal switch has to come out in order to get to it and replace it. Very common failure; not a WD-40 job.
