Fluid level is above full mark on dip stick. When driving car and turning right transmission acts like it slipped into neutral for an instant. Also when stopped at a light or intersection, (level road), the transmission is again acting like it is going into neutral. When you step on the gas to drive away it functions properly.
It acts like the fluid level is low and the pickup is not into the fluid even though the fluid level is slightly above full.
Is it possible it is over filled and causing these symptoms?
If one over fills an early power glide transmission what is the potential damage,if any?
Ted
Ted
