1958 290HP Ring question- Clem others - NCRS Discussion Boards
  • John N.
    • February 1, 1975
    • 451
    Opinion on using moly inlay versus file to fit plasma moly rings. (standard width)
    Regards
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 1958 290HP Ring question- Clem others
    Regards
    race car or show car ??
    • John N.
      • February 1, 1975
      • 451
      Show car. Thanks!
      • Clem Z.
        • January 1, 2006
        • 9427
        Show car. Thanks!
        just use the standard rings as file fitting is a PIA
          Ordinary moly rings should work fine - we build the Viper V-10 from the bare block up in the assembly plant, right next to the main line, and the moly rings are seated before the hot chassis comes out of the roll-test booth.
            • 43193
            Regards
            John-----
            If you use hypereutectic cast pistons, you may have to file fit the rings in order to meet the slightly greater end-gap specs for these pistons.
            • Tom P.
              • April 1, 1980
              • 1814
              John-----
              Joe,
              To the best of my knowledge, that is ONLY AN ISSUE when using Keith Black hypers. I've built one engine with K-B hypers---------never again (SPECIFICALLY because of the file fit top ring). Every engine that I've built since with hypereutectic pistons, such as Speed Pro, I use standard moly rings right out of the box (although, I DO check the gap before installing on the pistons).
              And last, the 290hp engine that John is referring to will have domed pistons, which I believe, ONLY come as a forged piston anyway.
              • Joe M.
                • February 1, 2005
                • 589
                Anybody using the cast Egge 283 domed pistons?
