66 Antifreeze - NCRS Discussion Boards
66 Antifreeze
  • John C.
    • May 31, 1993
    • 72
    66 Antifreeze
    Do they judge the color of the coolant ,and if they do who still makes green antifreeze ?
    THANKS
    JOHN
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 66 Antifreeze
    THANKS
    JOHN
    I don't know if the coolant is judged.
    When did it switch to green? 65? 66?
    • Kenneth B.
      • August 31, 1984
      • 2084
      Re: 66 Antifreeze
      THANKS
      JOHN
      NOW THAT THERE IS FUNNY! Or is someone bitter.
      • Larry M.
        • January 1, 1992
        • 2688
        Re: 66 Antifreeze
        THANKS
        JOHN
        I have never personally seen coolant color judged for Top Flight Awards.
        However, if you simply want green colored anitfreeze, Zerex still sells under their 5/100 Brand (5 year/100,000 miles). This is a conventional antifreeze, just like everyone used to use in their cars "back in the day". NAPA may have, or have them order it for you. The Prestone HOAT antifreeze in the yellow jug also has a greenish-golden tint.
        Many (self included) prefer Zerex G-05 HOAT antifreeze for the older cars, although its color is yellow/gold.
        Larry
        • Wayne K.
          • December 1, 1999
          • 1030
          Re: 66 Antifreeze
          Larry
          Follow this to read about the Zerex offerings.
          Go to www.farrelloil.com and under document library choose Farrell oil newsletter 3rd quarter 2006
          • John C.
            • May 31, 1993
            • 72
            Re: 66 Antifreeze
            I thought back when I was a kid all antifreeze was green .I can not believe they do not judge the color.
            THANKS
            JOHN
            • Michael H.
              • January 29, 2008
              • 7477
              Re: 66 Antifreeze
              THANKS
              JOHN
              I don't know when it changed to green but I know, for sure, that it was pink for 63 and at least most of 64.
              It looked red with something that made it look pearlescent that gave it a somewhat pink appearance.
              • Michael W.
                • April 1, 1997
                • 4290
                Re: 66 Antifreeze
                THANKS
                JOHN
                Taste test is out of bounds too.
                • Jim C.
                  • April 1, 2006
                  • 290
                  Re: 66 Antifreeze
                  I don't think coolant color is judged. But if you're to the point where you're concerned about it, then it sounds like you've got just about everything else covered and Top Flight should be no problem. I do know that the judging manual does say something about windshield washer fluid color however. You might want to check that out.
                  Jim C.
