FI fuel meter screw retention--ideas welcome - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5134
    John D, Jerry B, and others--what method do you use to repair a fuel meter housing when the screws that retain it to the upper bracket no longer will catch any threads? I'm doing a 7360 unit, but I'm pretty sure whatever fix you use would be effective across the board.
  • Dan H.
    • July 31, 1977
    • 1365
    Re: FI fuel meter screw retention--ideas welcome
    Mike, I always used heli coils of the appropriate size in the fuel meter, worked great.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Chris W.
      • September 30, 1982
      • 49
      Dan
      I agree
      Chris
      • Paul Y.
        • 570
        I also agree. Paul
        It's a good life!
        • Tom P.
          • April 1, 1980
          • 1814
          Yep, I've installed more than my share of helicoils in fuel meters. Those will be 10-32. I have also had to install a few helicoils in the forward part of the fuel meter for the main diaphragm cover. Those are 8-32.
          I've even had to install 2-3 on the back side of fuel meters for the hi-pres pump screws.
          The threads in die cast fuel meters seem to pull out more frequently than those on sand cast fuel meters.
          ZERO problems doing this.
