66 Oil Pressure Line - NCRS Discussion Boards
  • John C.
    • May 31, 1993
    • 72
    My friend tells me on his 65 396 the oil pressure line goes into the big fitting above the oil filter , on the 66 427 I am doing I keep ordering a fitting and it is to small for that hole , it looks like it would go in front of the filter. If it goes in the front hole what kind of fitting goes in the bid hole . The car is a 4speed .
    THANKS
    JOHN
  • John C.
    • May 31, 1993
    • 72
    Re: 66 Oil Pressure Line
    Somebody have a picture ,anybody .
    JOHN
    • John M.
      • January 1, 1998
      • 813
      John,
      The fitting goes in to a reducer bushing, I can't remember the size but the fitting that grabs the tube goes into a brass NPT bushing which has that size female on one side and the block size male on the other.
      • John C.
        • May 31, 1993
        • 72
        JOHN
        Was the fitting right above the oil filter or a little in front .
        THANKS
        JOHN
        • John M.
          • January 1, 1998
          • 813
          Sorry John,
          I can't remember will check tonight.
          • John C.
            • May 31, 1993
            • 72
            I keep ordering the fitting that goes into the block for oil pressure line , and I keep getting a fitting that goes a little in front of the oil filter , my friend had a pretty org. 65 and he said it goes in the big (1in ) right above the filter.
            JOHN
              John -
              As I recall, the adapter bushing for that application is 1/2" NPT male x 1/8" female NPT; the thread diameter on the 1/2" NPT end is 7/8". Which of the two holes (center or forward) are closest to 7/8"?
              • John C.
                • May 31, 1993
                • 72
                John
                The hole that is closest to 7/8 (1/2 n.p.t.) is front hole ,the hole above the filter is a little over an 1 inch .
                John
