1988 engine starting issue - NCRS Discussion Boards
  • Wayne R.
    • August 31, 1993
    • 13
    The car is stock with a 350 C.I., 245 H.P., TPI engine. Mileage is 30,000. Gasoline used is 93 octane.
    Upon a cold start the engine starts immediately. After fully warmed up and then shut down for 15 to 20 minutes, a restart will take a bit of cranking. At times I stop turning the motor over, wait a few seconds then try again for an immediate start.
    If I shut down the motor and wait for about 5 minutes, the engine will start up as it does upon a cold start.
    I have installed a pressure gage on the fuel rail and pressure holds with out any leak by for 30 minutes.
    I have recently installed a new coil, distributor rotor, module and cap. No change in the symptoms.
    Is this possibly an inherent condition for this model and one must live with it?
  • Bob H.
    • July 31, 2000
    • 789
    Re: 1988 engine starting issue
    Wayne:
    I had an 88 35th anniversary car. I believe we had intermittant problems with starting the car.
    As I recall it had something to do with the anti theft system not reading the key properly that would then activate the anti theft system for a timed period of several minutes.
    Hopefully, I'm not sending you on a wild goose chase but this is what I recall as a common problem in 88. I think it was called the VATS which I guess stood for vehicle anti theft system.
    Maybe you can find something on that. If not the problem, please forgive my very old brain.
    Bob
    • Bob H.
      • July 31, 2000
      • 789
      Wayne
      This problem was bothering me so I did some research. Check out this thread as it explains what the problem is. I think this is what you are experiencing. Hopefully, this helps keep you from spending more unecessary $$$
      Bob
      • Wayne R.
        • August 31, 1993
        • 13
        Bob,
        Thanks for your research and ideas on this problem. I will be checking out the VATS system and associated circuits.
        Wayne
        Originally posted by Bob Hoffman (34576)
        Wayne
        Bob
        • Paul H.
          • September 30, 2000
          • 678
          If it were a VATS related problem you would experience a no crank situation. Since your car is cranking but not starting I would look elsewhere for the source of your issue. It usually lies with faulty fuel injectors. I see that you have already tested yours so it is perplexing.
          • Wayne R.
            • August 31, 1993
            • 13
            Paul,
            Thanks for your input. I do not think it is an injector problem, but some how feel that it is fuel related. I'll keep researching and hopefully come across a fix.
            Wayne
