Need good photos of the underside of an Original Air Cleaner Lid for '62 340hp - NCRS Discussion Boards
  • Jonathan S.
    • February 20, 2009
    • 65
    Can someone post a couple of good photos of the top, side, and underside of an Original Aluminum Air Cleaner Lid for '62 340hp. I am trying to determine if I have an original or not.
  • Bill O.
    • April 1, 2006
    • 542
    Re: Need good photos of the underside of an Original Air Cleaner Lid for '62 340hp
    Jonathan:
    Let me know if you still need pictures after you take these measurements, as this is the easiest way to tell an original from a current reproduction. Other differences are very subtle.
    Measuring height from bottom of rim/base (as it sits on a flat surface) to bottom of first louver (closest to the rim/base):
    Original: 3/8"
    Repro: 2/8"
    Diameter of brass ring under wing nut:
    Original; 7/16"
    Repro: 3/4"
    Hope this helps.
    Bill
    • Jonathan S.
      • February 20, 2009
      • 65
      Thanks, Bill. This is really helpful, but if it wouldn't be too much trouble a couple pictures of the top, side, and underside of the lid would be especially helpful as well.
      I am trying to figure out if there are any differences between an orginal and a reproduction lid when it comes to the flame arrestor on the underside.
      • Vinnie P.
        Editor NCRS Restorer Magazine
        • May 31, 1990
        • 1557
        Jonathan,
        Check your email
        • Bill O.
          • April 1, 2006
          • 542
          Jonathan:
          The flame arrestor is the same with the exception of the composition of the retardant material. Let me know whether you got from Vinnie what you need; otherwise I'll post some pictures.
          Bill
          • Jonathan S.
            • February 20, 2009
            • 65
            Thanks Vinnie. Just what I needed.
            • Jonathan S.
              • February 20, 2009
              • 65
              The pictures confirmed for me that I have an original lid, but the flame arrestor is missing. Anyone know where I can get a flame arrestor for my lid? I'll take a good reproduction, if that is all I can get.
              • Jerry W.
                • January 27, 2009
                • 588
                pardon my stupitity....what is the "flame arrestor" that you are refering to ?
                • Jonathan S.
                  • February 20, 2009
                  • 65
                  A picture would be better, but I will take a shot at describing.
                  It is about an 8-1/2" diameter metal disk that has cutouts that look like fan blades attached to the back of the lid via a brass grommet on the through hole of the lid. Between the lid and the metal disk is a material (originally a combination of goat hair and jute) that serves as the flame retardant, making the unit a flame arrestor. I hope this helps.
                  • Jerry W.
                    • January 27, 2009
                    • 588
                    holy air filter components....i bought a new 62 vette and had it 6 years....i was a hands on guy and do not remember a flame arrestor being there in my air filter....i remember cleaning and lightly oiling the foam element held in place by a zig-zag spring on a regular basis......i am currently rounding up parts for an original serial number 62 340hp engine.....where are these air filter components shown ?...thanks for the reply
                    • Bruce B.
                      • May 31, 1996
                      • 2930
                      Attached a 4 pictures of the top and bottom of 62 Corvette air cleaners.
                      I believe #2 which is on my 340 HP 62 is the correct filter. I have put abouy 30,000 miles on this filter, as you can see the flame arrestor has gotten hot a few times.
                      Note the size of the brass washer.
                      As far as the foam and the zig zag retainer goes. If you are going to drive the car get a AC A350C paper filter and install it.
                      The foam filter is correct for judging but turns to dust after a few years.
                      I will show a picture of the deteriorated foam filter in another post.
                      • Jonathan S.
                        • February 20, 2009
                        • 65
                        Now that we are all up to speed.
                        • Jerry W.
                          • January 27, 2009
                          • 588
                          Like i said....I had a new 340hp 62 and my air cleaner did not include a "flame arrestor".....I just looked at Noland Adams 1953-1962 restoration guide and he states on page 331 that the 1961 had one but the 1962 did not.
                          • Bruce B.
                            • May 31, 1996
                            • 2930
                            The NCRS 1961-1962 Judging Manual states that the air cleaners (for both 61 & 62) underside "contains a flame arrestor which measures 8 3/8" in diameter, held in place by a 7/16 grommet-type brass fastener for the single four-barrel cover".
                            So Johnathan, if you are getting the car flight judged go with a air cleaner with a flame arrestor.
                            • Bruce B.
                              • May 31, 1996
                              • 2930
                              Johnathan,
                              Concerning the availability of a flame arrestor for a 62 air cleaner.
                              I believe Vette Products of Michigan currently makes the whole air cleaner assembly.
                              You might check with them for the flame arrestor.
                              Good luck.
