1972 Lt1 w/press-in studs and 2.02/1.94 valves - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    I know you're going to say this can't be, but here goes:
    My 1972 LT1 w/ac has press-in rocker studs and 2.02"/1.60" intake/exhaust valves. With the exception of a few individuals they all say 70-72 LT1 came with screw-in rocker studs, guide plates and 2.02"/1.60" valves. Other say this was the case with late 1972 model year LT1's.
    All the pertinent casting #'s and date codes are right on and within the date code tolerances. See the following:
    Vehicle Identification Number: 1Z37L2S523822
    1 = Chevrolet Division
    Z = Corvette
    37 = Coupe
    L = LT1 engine
    2 = 1972
    S = St. Louis plant assembly
    523822 = Production sequence number (during the month of May 1972 Corvette units 22611 through 25225 were produced)
    Trim Tag:
    Body - K14 = Built June 14, 1972
    Trim - 400 = Vinyl black
    Color - 912 = Sunflower yellow
    Engine Stamp Pad:
    V0421CKY 12S523822
    V = Flint Plant
    0421 - Date Code = April 21 (engine assembly date)
    CKY = 4 speed, mechanical lifters, Holley 4BBL
    12S523822 - 1 = Chevrolet, 2 = 1972, S = St Louis, 523822 = production sequence number
    Block:
    3970010 - 4 bolt main
    Date code: D82 - D = April, 8 = 8th day, 2 = 1972
    Transmission:
    VIN (Vehicle Identification Number): L2S523822
    Main case part number: 3925661
    Extension (tail) part number: 3978764
    Side cover part number: 3952648
    Code: P2E19A
    P = Muncie 4-speed
    2 = 1972
    E19 = May 19th
    A = 2.52:1 - First gear - wide ratio
    Rear:
    AAW143 1E
    AA = 3.55:1 Corvette positraction axle
    W = Warren, MI plant
    143 = Day of year: May 22, 1972
    1 = Shift
    E = Positraction Source: Eaton
    Alternator:
    11 00544 61 - 1972 Delcotron 61 Amp Alternator - with A/C
    12VNEG = 12 Volt - negative ground
    Date Code: 2E17 - 2 = 1972, E = May, 17 = 17TH day
    Carburetor:
    Holley 4150 - with standard transmission
    Carb list # R 6239-1
    Date Code: 244 - 2 = 1972, 4 = April, 4 = 4th Week
    Starter:
    1108418 - 1972 Corvette 350/255HP with manual transmission
    Date Code: 2D26 - 2 = 1972, D = April, 26 = 26th day
    Intake Manifold:
    3959594 -1972 Corvette 350/255HP
    (note: date code is under the oil splash shield on the under side of the manifold. The shield, if removed will be damaged.
    Exhaust Manifolds:
    Front side:
    Left - 3932461, RH6
    Right - 3932461, RH6
    Back side:
    Left - date code: E17 - E = May, 17 = 17th day
    Right - date code: E12 - E = May, 12 = 12th day
    Distributor:
    1112101 - 350/255HP / LT1
    Date Code: 2E18 - 2 = 1972, E = May, 18 = 18th day
    Heads:
    3973487X - This head is identical to 397387. The 3973487X was used only on late 1972 models.
    Date Code: Left - C62 - C = March, 6 = 6th day, 2 = 1972
    Date Code: Right - C142 - C = March, 14 =14th day, 2 = 1972
    Value Covers:
    Left hand - 3989005
    Right hand - 3965542
    Master Cylinder:
    5480346
    Stamping on flat ground area: PG
    Seat Belts:
    Driver & passenger lap belt - model C-15
    Date Code: 1-E-72 - 1 = week, E = day (Friday), 72 = 1972
    Driver & passenger shoulder belt - model C-25
    Date Code 1-F-72 - 1 = week, F = day (Saturday), 72 = 1972
    Wheels:
    K 1 3 3 (v)*1 AZ -------------- K 1 2 5 (v)* 1 7 AZ (spare)
    K = Kelsey Hayes ------------- K = Kelsey Hayes
    1 = Romulus Plant ------------ 1 = Romulus Plant
    3 = 1973 ------------------------- 2 = 1972 (spare)
    3 = March ------------------------5 = May
    1 = 1st day -----------------------17 = 17th day
    AZ = Corvette (15X8) -------- AZ = Corvette (15X8)
    * (v = valve stem hole)
    LOF Glass:
    Left side:
    Soft-Ray
    Safety AS2
    Solid tempered
    DOT 15
    M74
    Flo-lite
    Dated Code: JY = May 1972
    Right side:
    Soft-Ray
    Safety AS2
    Solid tempered
    DOT 15
    M54
    Flo-lite
    Windshield:
    Shaded
    Soft-Ray
    Safety AS1
    Laminated
    DOT 15
    M24
    Flo-lite
    Windshield
    Date Code: IY = June 1972
    I have also attached a couple pictures of one of the heads showing the valve train and one of the valves with mic showing the size of the intake valve.
    I know this is long and spread out, but I would like to get some feed back from others. I have been emailing back and forth with Joe Lucia and we concluded the heads are an aberration. Given the dates and casting numbers I am confident the heads are original the car.
    Your comments.
  • William C.
    • May 31, 1975
    • 6037
    Re: 1972 Lt1 w/press-in studs and 2.02/1.94 valves
    For starters, try measuring the exhaust valve again, with a 2.02 intake, which is correct for the engine you can't get a 1.94 exhaust in the head. Depending on how late the car is, the screw in studs were discontinued in the 73 model year so that could have been a running change or???
    Bill Clupper #618
    • Jerome P.
      • October 22, 2006
      • 607
      Re: 1972 Lt1 w/press-in studs and 2.02/1.60 valves
      Bill Thanks for your comments. I was not thinking when I posted initially. The 1.94 valve size is the intake valve size on the standard 350 engine. My mistake, I know better. I have edited the texted of my first post; corrrecting the error.
      I did measure the exhaust valves and just didn't memtion it. They do measure correctly at 1.60"
      It is possible like you said, the heads maybe for the 73 model year. The car is a June 14th built vehicle.
      Are you sure that they discontinued the screw-in studs with the '73 model year?
      Any follow-up will be appreciated.
        Bill-----
        I believe that L-82, first available for the 1973 model year, used screw-in studs through its last year of production in 1980. So, I think these late 1972 LT-1 heads of Jerry's amount to some sort of "aberration".
          • 11608
          Slightly different topic...
          Nice numbers, but would you also happen to know your water pump?
          See thread:
          https://www.forums.ncrs.org/showthre...71288&uid=9382
          Patrick
          • Jerome P.
            • October 22, 2006
            • 607
            Pat, I have the car at the garage. Next visit I will get the number. Probably in a couple of days.
            • William C.
              • May 31, 1975
              • 6037
              My error, should have checked the parts book, SHP kept the screw in studs at least thru 1980 according to the parts book.
              Bill Clupper #618
                • 11608
                Next question is... what head gaskets were on the motor when these heads were removed? If they were the original steel shim type, that would go a long way toward establishing them as "likely original." If the gaskets were of another type, then anything could be possible.
                One of the heads on my 71 cracked, and I bought a date matched set for the car. No reason someone couldn't have done the same for this car.
                Patrick
                  Bill----
                  The P&A Catalogs could be incorrect on something like this. However, I cross-checked with several other references as well as my own personal experience with L-82's to confirm that screw-in studs were used on all L-82's.
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    the fact the heads are painted inside the valve spring area and it had composition head gaskets leaves me to believe it is not cherry
                    • Bryan M.
                      • April 1, 1999
                      • 386
                      I pulled the oil plug out of the driver-side valve cover on my 1972 LT-1 with a/c to take a peek and found the screw in studs. It's a April 27 build date and the head is a 3973487X with a date code of C2 2.
                      • John P.
                        • April 2, 2009
                        • 11
                        Point of reference: Have knowledge of a 72 LT1 air coupe, ser# 22741, build date 6-2-72. Heads have screw in studs and guide plates. Built only 2 weeks before your ser#.
                        • Greg Y.
                          • February 26, 2008
                          • 38
                          If it helps, I have a 72 A/C LT1 coupe vin 23827 build date K14 and a 72 LT1 convertible build date H22 and both have screw in studs and guide plates.
                            • 15573
                            The fact that your heads have painted valve springs doesn't tell us much. The WAY they are painted tells us everything. See the attached 6000 mile 1972 LT1 heads for the original paint pattern.
                            Well you guys won't get to see the original mask pattern for the exhaust ports and spark plug ports because the board says I followed an invalid link -- after waiting five minutes for the first picture to load. Your loss.
                            Edit add: one more try: Screw it.
                            • Chuck S.
                              • April 1, 1992
                              • 4668
                              ...after waiting five minutes for the first picture to load. Your loss.
                              Awww...Com'n, Terry...At least give us a clue as to what the pictures "say".
                              I believe the TIM&JG(?) says optional engines with aluminum valve covers were painted with stamped steel covers in place, and that these were reclaimed and used again for the same purpose.
                              Clearly, there were no valve covers in place when the heads were painted, but there does appear to have been an effort to mask the valve area with something that extended from one end of the head to the other. Paint overspray on the upper and lower periphery of Jerome's valve area is light as might be expected for a factory paint job.
                              Factory, or...??
