Control Arm Ball Joint - NCRS Discussion Boards
  • Brian G.
    • February 1, 2001
    • 159
    I can't get the lower control arm ball joint to take any grease. The grease fitting works and I switched it with another working fitting but no luck. Just wondering what would cause this and if there's a fix. Thanks for any help.
    • 6940
    Re: Control Arm Ball Joint
    Brian, Sometimes The Grease Hardens Over Time in the joint, You Might Try A Small Propane Torch On Low, Heat Around The Fitting For A Moment, Sometimes This Lets The Joint Acceppt Grease . The Other Possiabilty Is The Joint May Be Wiped Out .which Is Common On Older Cars.
