Holley carb - NCRS Discussion Boards
Holley carb
  • Jim T.
    • March 1, 1993
    • 5351
    Holley carb
    Request any tips on removing a metering block from a Holley carb. The rear metering block has has not been removed in a long time and the gasket is retaining the metering block to the carbs body.
    Have installed Renew Kits in Holley's before several times in the last 30 years, but this metering block is secured very well.
    With the new type of Holley gaskets I don't expect this to happen again.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Holley carb
    i just use a brass punch on the sides to move it back away from the main body
    • Jim T.
      • March 1, 1993
      • 5351
      Re: Holley carb
      I know you have done this procedure many times, I will try your method.
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: Holley carb
        perma tex also sell a spray can of "gasket remover" that works well to remove the gasket
