Did my 67 come this way from the factory? - NCRS Discussion Boards
  • Bill I.
    • January 29, 2008
    • 554
    It's a 67 L79, no a/c, no ps. It has a 2 groove pulley. Can see the advantage in case the alt belt goes, but my question is, did some 67's come this way? Thanks, Bill.
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Did my 67 come this way from the factory?
    yes, two groove pulley on crank and water pump.
    • Bill I.
      • January 29, 2008
      • 554
      Thanks Gene, now next question, how would you change the small belt if it went south? Bill
      • Gene M.
        • April 1, 1985
        • 4232
        Remove the fan and clutch so you can pull down the pulley to slip the belt on. Pulling the pulley back over the pin on the pump shaft may require a little leverage against the crank pulley.
        • Peter J.
          • September 30, 1994
          • 586
          I have always loosened the fan bolts and slipped it over the pulley.
          • Gene M.
            • April 1, 1985
            • 4232
            Peter, I think you will find the correct sized belt will not slip over till you lower the water pump pulley some. The belt if it just slips over will be too loose to drive the pump without slippage at high RPM.
