There is a huge gap at the top between the door and the front clip.
This has been increasing over the years.
I have the body on a body dolly and the doors off. I've just replaced the rocker channels on both sides from a donar. While doing this, I noticed that the bond between the firewall and the front of the door pillar channels has let go. Probably because the #1 and 2 body mounts and the front of the rocker channels disintegrated due to rust.
There is a wider gap between the top of the firewall and the door pillar than at the bottom.
What's the easiest way of rebonding this?
I suspect your gonna tell me that the front clip has to come off. Can I pry off the firewall just enough to get adhesive in there without taking the firewall off completely?
) I would analyze it this way: All those bonds were made at the same time with the same batch of adhesive, and they have all been exposed to the same environmental conditions for the same amount of time...to assume that one bond has selectively failed while the others remain strong seems illogical. As Lyle says, you definitely want to use a Fusor type product for a 73 if you need to repair bonds.
