75 Exhaust System Judging - NCRS Discussion Boards
  • Alger R.
    • September 30, 1999
    • 279
    Help!! My 75 L48 Exhaust System calls for a 2 " system front to back. Only systems available today from Corvette supply houses are 2 1/4 at the year Y-Pipe and a 2 1/2 inch fron exhaust pipe running to the Cat Conv. How many points will be lost for a system with incorrect diameter system???
    AL
    75 Convertible
    L48 M20
    Bright Green / Saddle
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 75 Exhaust System Judging
    Alger on the exhaust system or any other item that is judged. Deductions are made if the item's deviate from the original in 5 areas. So each area is given 20% each so if the Configuration, Finish differ from the original and 20 points are for originality it would merit a 8 point deduction. If there were more deviations more deductions would occur. So if you still have your original pipes compare them to the replacement and judge them for the differences. Paul 18046
