Thanks for the responses. The line to the rear is still blanked off. Since last nite's post I have: 1) checked to make sure that brake shoes are being deployed against drum when pedal is pressed; yes they are, and there is no leak from the wheel cylinder. 2) with power bleeder, bled right front again to solid fluid and beyond (8 oz): pedal still moves to near floor. 3) disconnected line to right front and re-installed blank plug to see if I still get a firm pedal on the left front; left front still has firm pedal. 4) removed blank plug, re-connected line to right front, removed hose at right front, replaced with NEW hose, tightened all connections, bled right front to solid fluid and beyond (12 oz), no leaks;pedal still moves to near floor.
Is there anything in the wheel cylinder that could be "absorbing" pressure? I'm running out ideas.
Steve
Steve
