I didn't intend for this to becom a saga, and almost embaressed enough to discontinue the post. However, here is the latest report.
Harry and Tim suggested that I check the shoe adjustment to insure that there was no excess travel in the system. I checked the right front and adjusted it a bit to make sure it was slightly contacting. After this the pedal still went "close to the floor". At this point I measured the pedal height above the floor at the start position (fully released) and got six inches. I pressed the pedal with my foot as far as I could, and the measurement was three inches. At three inches from the floor the pedal is hard. I then removed the blank plug from the the brass block and reconnected the line to the rear wheels. I checked the shoe adjustment of the rear wheels and bled the right rear then the left rear. After bleeding, I pressed the pedal and it went to three inches from the floor. To recap, at this point lines are connected to all four wheels, the pedal travels one half of the distance to the floor and does not return without pulling it back up. This is different than the response I got when only the master or the master and left front were connected.
Perplexed in Plano.
Perplexed in Plano.
