Team, I really need your best advice on a electrical problem. Just re/re rebuilt my L-36. Everything is back together, two weeks ago I posted that I had the engine going but my main "pink" +coil thru firewall to ignition wired fried. Pulled cluster, tore into harness replaced pink wire only one damaged from ign switch to coil and also pink wire on firewall to starter. Today after hrs of work getting cluster back in ( I had numbered all wires to re-hook up), I turned the Accessory switich to left, lights came on, radio and clock worked, headlights buckets moved, then within 30-45 seconds burning smoke from around wiper motor/ignition shield/firewall/resistior. Burning electrical smell. I imediately uppluged battery and cannot visually see any burnt wires, but I just want to CRY !!!
- I had RE-tightend my cig lighter and it is hooked up correctly.
- I had my wiper SWITCH apart and tested it as per recent Restorer article, as it would turn on and never shut off. This could be an issue??
-I obviously had all the wires off my Starter and believe I have them on correctly. Will dbl check.
-My oil sender metal coil is NOT touching the Ballast Resistor. The smoke was definately coming from firewall side center area, not underneath dash.
HOW DOES ONE FIND A GROUND FAULT !!
PLease, please. Trouble shooting ideas's please, area's to double check. I have had this cluster out 3 times in 10 days, I'm 99% certain all the light bulb sockets and blk ground to top spade over Tach is on correctly.
YOUR BEST ADVICE PLEASE, I WOULD LIKE TO GET SOME IDEAS, MY FATHER IS AN ELECTRICIAN AND WOULD LIKE TO POINT HIM TO SOME AREA'S TO DBL CHECK FIRST. I HAVE A NEW 66 LECTRIC LTD WIRING DIAGRAM also. THANK-YOU....THANK-YOU...THANK-YOU
Also the single thin black wire needs to be grounded at the outboard starter bolt. One last thing, make sure that nothing is touching the backside of the ballast resistor.
