Does anyone have information about the number of '66 M-22/427 combos are out there? Also, if anyone has noted any differences in the internals of the HD427s vs. the 427/425 if they had the opportunity to do the documentation and rebuild themselves? I've seen a few M-22 equipped 427 '66s over the years, but never had the opportunity to check internally.
1966 M-22/HD 427 help
Tags: None
- Top
Re: 1966 M-22/HD 427 help
Peter --- I'm sure you're aware of the 1966MY M22 production figures quoted by A. Colvin and (in the case of Corvettes, confirmed by Noland's Vol 2).
That is: Passenger 2; Chevelle 12; Corvette 15.
I would assume that all these ended up in big blocks, if not entirely hooked up to 427's.
I'm a bit confused; by your "internals of the HD427". Are you referring to the M22 trans or the early L88-equivalent engine assemblies ? Could you be more specific ?- Top
Wayne, I am trying to see how many M-22s were bolted up to the HD427s, and if internal parts such as the camshaft, are different from the regular production L-72 427/425s as well.- Top
- Top
So is it safe to assume that all the M-22 cars are HD427s?- Top
That was my understanding too. Just wanted to double check with you guys.- Top
Does anyone have information about the number of '66 M-22/427 combos are out there? Also, if anyone has noted any differences in the internals of the HD427s vs. the 427/425 if they had the opportunity to do the documentation and rebuild themselves? I've seen a few M-22 equipped 427 '66s over the years, but never had the opportunity to check internally.- Top
- Top
