I was trouble shooting my rear dome light on my 1970 Convertable and found I am not getting 12 volts to the orange wire. When I applied 12 volt the light worked. Also the rear center compartment also worked. What do you recommend the rear center compartment light worked prior and ran down the battery, but now has stopped working. Has anyone metered out this wire? Does it go through the emergency brake console? Do the dome light and compartment light join together and where? My interior lights work fine under the dash.
