C-1 Wheel Cylinders - NCRS Discussion Boards
C-1 Wheel Cylinders
  • Jerry C.
    • November 1, 1995
    • 741
    C-1 Wheel Cylinders
    Could someone please post the GM numbers for standard wheel cylinders for all wheels. Thanks in advance.
  • Ian G.
    • September 3, 2007
    • 1114
    Re: C-1 Wheel Cylinders
    base brakes
    cast 5453821 front RH, part 5455478 1 1/8" bore 1953-59
    cast 5453822 front LH, part 5455479 1 1/8" bore1953-59
    cast "5459527" (or "527") Front LH, 1 3/16" bore 1960-62
    cast "5459528" (or "528") Front RH, 1 3/16" bore 1960-62
    cast 5453820 rear LH & RH, part 5453819 bore 1" 1953-55
    cast 5450649 rear RH, part 5459918 1" bore 1956-62
    cast 5450649 rear LH, part 5459917 1" bore 1956-62
    If you can find them in the original tin cans they will have the original screw top bleeders (for 53-59), otherwise with later modern bleeders.
    I don't think bleeders are judged, but its a point of interest. You can get the original style bleeders from Corvette Central in any case.
    updated per info from Gary Chestnut & John Scopelite below
    • Gary C.
      Administrator
      • October 1, 1982
      • 17549
      Ian, bleeder valves were changed from a hex bolt to a nipple type some time in '59 as I recall. Gary....
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • John F.
        • March 23, 2008
        • 2395
        Jerry, I have a 5453822 that I took off my 62 and replaced with a generic rebuilt one. It is 1 1/8 bore. These numbers are cast on it. On the other side is Delco Loraine Prod Dayton O USA. Do you need one?
        John
        • Ian G.
          • September 3, 2007
          • 1114
          Thanks Gary, good to know!
          • John S.
            • July 29, 2009
            • 640
            53-55 rear #5453820. need brass connectors #3696553 to use these wheel cylinders.
            • Roy B.
              • February 1, 1975
              • 7044
              Original cyl.
