Does anyone have a picture of the correct blower motor , mine quit this weekend, im trying to figure if orig. to car, the aim says part no and date code on mounting flange but cannot find a date or part no. I don't know if I should even bother with it,does anyone repro. a correct blower motor. thanks Ed.
72 blower motor w. a/c
Re: 72 blower motor w. a/c
There's really no call for suppliers to tool up to 'repro' the heater fan. I think you'll find that Corvette wasn't 'unique' in this aspect versus other Chevy passenger cars of the era. The typical 'hit' for a decent used/original fan assy from a scrap yard car from the same era is $10-20.
And, YES, the A/C version of the heater fan differed from the non-A/C fan. The A/C version sported a hole on the LH side of the motor case to accept a cooling tube that connected to the Harrison air box...- Top
Jack, paragon sells a correct replacement for 40.00 , do you thing this will take a hit when judged , im planing on having car go meet next year, or should I get a used one? thanks for you reply, EdNew England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
I have no idea of what it is that Paragon's selling. I do know that the fan assy's flange was date coded (starting in '65) in addition to having PN embossed on it.
I PRESUME this practice continued into the early 70's... So, if Paragon's advertizing a 'correct' reproduction, does their descriptive text include mention of the buyer's need to supply information (model year + VIN) to get the date code to match?
Bottom line, heater fans are pretty hearty critters. A good used assy should perform and last at a reasonable cost. One key to checking operation absent putting power to the fan, is spinning the squirrel cage by hand.
If it turns freely, the odds are VERY good the used fan assy is perfectly functional. If its frozen or turns with HIGH friction, go find another one. Taking these apart to replace bearings and/or brushes in the DC motor is NOT fun...- Top
Jack, they're just saying "correct" w a/c , no dating or part no. Im going Carlisle at the end of the month, I guess I'll do some looking there. thanks Ed.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Ed,
I'm sure my 71 is the same as your 72. Lets take a look tomorrow morning.- Top
