68 327 with factory original Rovhester carb
If I suspect moisture or water in the carb, how do I clean it correctly and will I disturb the settings made by the rebuilder.
Car is factory original, no modifications
I think I got some bad fuel with moisture and will also clean the filters but I am concerned I may have moisture or dirt in the fuel bowls inside the carb
Thank you in advance
Kurt
Kurt
