Hello Everyone,
I pulled the brake calipers off my '67 to replace them with rebuilt units and in doing so I noticed I have two different bolt lengths from the same caliper - 1-1/8" and 1-1/4".
I did a search in the achieves but couldn't find the info, so my question is "what is the correct bolt length for mounting the calipers".
Many thanks.
Many thanks.
) found the caliper mounting brackets in the P&A30 catalogs, under Gr 5.001. It shows the front caliper adapter (ie. mounting) bracket changing for '68-70 (it's a Jan '70 catalog) from 3864114-6 ('65-7) to 3928649-50 (LH/RH both cases). So maybe this is why a longer bolt was necessary.
