67 BB oil pressure line - NCRS Discussion Boards
  • Mark F.
    • May 11, 2008
    • 68
    Does anyone have a good picture of how the oil pressure line runs from the engine block connection to the firewall gromet? It is on a 67 L36/ 390 car, 4spd,pb, specifically where the coils of the steel line are located? I checked the AIM and it doesn't give me, at least mine doesn't, any placement or reference point.
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 67 BB oil pressure line
    Mark,
    the coils should be at the wiper motor recess just as it bends to go down the firewall to attach to the fitting in the block. Sorry no picture right now. But the coils were desinged to be at the 90 degree bend and act as a shock absorber between the motor and the gauge.
    Rich
    • Mark F.
      • May 11, 2008
      • 68
      Rich,
      Thanks for the info. To make sure I understand this, the coils do not go against the vertical part of the firewall, behind the valve cover. But go in the wiper recess' horizontally. In other words, if I was to look in the engine compartment the oil line would screw front (front of recess)to back ( black grommet)
      • Rich P.
        • January 12, 2009
        • 1361
        Originally posted by Mark Fedeli (49007)
        Rich,
        Mark,
        the best way to describe this is the coils are at the middle of the bend. So you will have some on the horizontal leg and some on the vertical leg. There will be a coil in the wiper recess and a coil along the firewall behind the valve cover.
        Just imagine the coil section is a "Slinky" when you bend the slinky in the middle you will get a right angle. Now keep in mind this is how I have seen most originals. I'm sure there could be an example of a car with the bend before or after the coils but I don't recall seeing it that way.
        Rich
        • Mark F.
          • May 11, 2008
          • 68
          Rich,
          Gotcha. Perfect. Thanks a bunch.
          Mark
          • Del S.
            • March 1, 1991
            • 83
            Im having trouble visualizing the description , hope someone can supply a pic . Is the oil line the same for the L71 . thanks
            • Rich P.
              • January 12, 2009
              • 1361
              Del,
              This is a repro line on a L-71. It should actually be shortened on the vertial section and the coils closer to the firewall and the bend more in the coils and not on the vertical section.
              Rich
              • Stephen L.
                • May 31, 1984
                • 3148
                Requested photos..... 67 427/390 4SPD Original oil line.
                • Del S.
                  • March 1, 1991
                  • 83
                  Rich and Stephen , thanks ....the pics are a big help.
