82 Corvette. Please verify this relay. - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    The relay that is circled in blue to the immediate right of the wiper motor. What is it? This is on an 82 Corvette.
    -Dave
  • Jack H.
    • April 1, 1990
    • 9906
    Re: 82 Corvette. Please verify this relay.
    I'm surprised it's not defined in your copy of the shop manual or the owners manual... They typically have electrical component 'location' tables.
    • Jim T.
      • March 1, 1993
      • 5351
      I will guess, power window relay, but then what is that next to it?
      • Tom H.
        • December 1, 1993
        • 3440
        Is it the hood louvre relay ??? Does it have a part number on it ? Possibly 14039681 I believe this number was called the Air Cleaner Door Solenoid.
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
        • Edward J.
          • September 15, 2008
          • 6940
          David , I Work For Chev. Back In Those Years As A Line Mechanic, If I Remember Correctly Thats The Fuel Pump Relay,and The Item Next To It Is A Map Sensor.
          • David S.
            • August 9, 2009
            • 595
            Thanks for the replies guys! I needed to change the fuel pump relay and did. Just got confused based on some false information I was given, on the location of the fuel pump relay.
            Thanks again,
            -Dave
            • Tom H.
              • December 1, 1993
              • 3440
              Hi Dave:
              Was the highlighted relay the fuel pump relay ?
              Tom Hendricks
              • David S.
                • August 9, 2009
                • 595
                Tom,
                -Dave
