67 Corvette PCV and A.I.R. Smog Intake Manifold Fittings - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    Hi Guys,
    I am looking for two intake fittings for a 67 400 with A.I.R. Smog. The first fitting is for the PCV Valve hose that goes into the side of the intake manifold. The second fitting is for the hose that goes from the diverter valve into the intake manifold. Both are on the passenger side of the intake manifold. I've called most of the venders as well as spoken to a few of the specialists about these fittings and I still cannot come up with them. Does anyone know where I can find these two fittings?
    Thanks in advance,
    -Dave
  • Ara G.
    • January 31, 2008
    • 1108
    Re: 67 Corvette PCV and A.I.R. Smog Intake Manifold Fittings
    Check with Bill Hodel. He is a long time NCRS member and has many A.I.R. parts and has a great amount of knowledge on these systems. He advertises in the Driveline. I will try to find his number for you and email you. Good luck. I too have a 67 A.I.R. coupe L79 car and the parts are hard to come by. When I see them, even if I don't need them I pick them up. I have a bunch. Good luck. ARA
    • David S.
      • August 9, 2009
      • 595
      Ara,
      Dave
