62 Instrument Cluster - NCRS Discussion Boards
  • Wes S.
    • May 31, 1982
    • 202
    Thinking about powder coating my instrument cluster any pros or cons?
  • Terry D.
    • May 31, 1987
    • 2690
    Re: 62 Instrument Cluster
    To what advantage? Painting it is very simple once it's out and done correctly should last a very long time. Just my old two cents.
    • Greg S.
      • July 31, 1995
      • 243
      Don't even think about it. The pot metal will deform from the heat. You may ruin the cluster. Ask me how I know.
      Paint it at all cost.
      • Bruce B.
        • May 31, 1996
        • 2930
        Some powder coat materials have poor UV resistance will deteriorate in the sun.
        Paint it.
        • Wes S.
          • May 31, 1982
          • 202
          Thank you for your respnses. My powder coater said it might warp. Painting looks like th way to go.
          • Joe M.
            • February 1, 2005
            • 589
            Sprayed mine with black dupont coralar epoxy after priming with dupont variprime. See the dupont equivalents today. Coralar epoxy was for top coat use.
            • David D.
              • December 1, 1977
              • 231
              My 62 cluster housing looks very 'tan' rather than fawn beige. I am going to repaint it and wondered about the proper color. From the info I see, it appears that it should be painted with the Trim color found in the NCRS Spec Guide. Years ago when speaking with one of the plant painters I asked about painting the clusters. I have his written response that indicate the cluster was painted as in picture (page 210 of Vol 1, of Noland Adams Complete Corvette Resto. . . .Guide). He went on to say 'then removed - sanded & painted in a paint repair booth where the side inserts & black out work was done'. My cluster does not look like it has been repainted and is a dull tan, should it be the dull tan or more metalic? Any recomendations of paint brand and source? I would prefer one of the original vendors however several have said it would not hold up in sun due to the current formula contents.
              David Dawdy
